spare parts
andy engelsk
Registrert: 10 okt 2006, 21:46
spare parts
Legg inn av andy engelsk » 09 jan 2007, 18:34
can you tell me the best place to get good used parts? im having no luck with the local scrapyards, old 900s seem a bit thin on the ground.
is there a specialist saab breaker in norway?
regards
andy
Ottar N398
Medlemsnummer: 398
Navn: Ottar Amdal
Legg inn av Ottar N398 » 09 jan 2007, 18:44
Well you allways got the club :wink: Alot of us has some partcars standing around and we might just have the part that you need :wink:
Don't really have any better tips :roll:
900 T16 M89 4d
9-5 Estate 2,0t M05
Legg inn av Hjelle, N6 » 09 jan 2007, 18:49
You have Speedparts at Kjeller, http://www.speedpartsnorway.com
Legg inn av Tor N12 » 09 jan 2007, 19:00
Hjelle, N6 skrev:You have Speedparts at Kjeller, http://www.speedpartsnorway.com
They dont have any used parts..
Send Øyvind N43 a PM, ha has a lot of used spareparts ;)
Legg inn av Hjelle, N6 » 09 jan 2007, 19:05
hm, I don't read used... :( :oops: :oops:
andy engelsk
Legg inn av andy engelsk » 09 jan 2007, 20:57
some intresting turbos at speedparts wish i had some spare cash!
what im needing is a newish wastgate actuator, my car suddenly went to half boost, cant find any leaks in the charge system so i assume its this or the apc valve.
either way spares are proving hard to source and iv been stung for import tax on parts sent from the uk :shock: , so unless its totaly needed i wont be doing that again. :cry:
regards
andy
herman86-N693
Registrert: 13 jun 2006, 19:52
Medlemsnummer: N693
Navn: Andre
Bil: NG900R
Legg inn av herman86-N693 » 10 jan 2007, 00:50
Andre - N693
Saab 900SE Turbo 97 (3d)
Tidligere biler:
Saab 9000CC Turbo 87 mod (2 år)
Saab 9000i CC 87mod (døde tidlig)
Legg inn av Hjelle, N6 » 11 jan 2007, 13:34
andy engelsk skrev:what im needing is a newish wastgate actuator, my car suddenly went to half boost, cant find any leaks in the charge system so i assume its this or the apc valve.
Have you checked that the stay from the turbo that goes into the wastegate don't touch the membran?
Trond N47
Medlemsnummer: 047
Legg inn av Trond N47 » 12 jan 2007, 21:32
And did you check that the wastegate stay is connected below the turbo? (to the integrated wastegate). Seems that your APC valve doesn't work. Usually it goes like this if the connections are mixed. Or the APC (magnetic) valve is not working.
I have one APC valve from 9000 85, guess thats the same part. I also have some wastegate valves from Garret T25 if they're fitting. You gan get those for just above the shipping cost if you are interessed.
Trond #047
94 SAAB 9000 2,3T CSE
andy engelsk
Legg inn av andy engelsk » 13 jan 2007, 17:55
thanks folks,
the wastgate rod is all intact and conected, but feels a little to easy to move. this is why i think it may be a weak spring. however this loss of perfomance was instant so i now feel its the apc valve, i had a manual boost control fitted during the summer and am not sure if this screwed up the valve.
so first thing try a new apc valve.
all seems a bit pointless till the weather clears up though, who nedds 18 psi boost in this icy weather! :wink:
1991 900 Carlsson Edition Turbo
