service på 9000?
Danielm
Registrert: 08 aug 2009, 00:37
Navn: Daniel
Bil: 9000 CS 92 B202I
service på 9000?
Legg inn av Danielm » 03 jan 2010, 19:27
bil: saab 9000 cs 1992 modell 131 hk 2.0 16v ikke tenkassett eller turbo. bilen har rullet snart 200000. (197200 står det nå idag)
da jeg kjøpte bilen var det ikke noe service hefte eller noe.
bor i bodø og her er jo imaas og regner med de tar service siden de holder på med saab og nissan. hvilken service er det de tar hviss jeg stikker innom med bilen på 200000 km? og hva koster det og ? og hva bytter de?
Jim S. N1578
Registrert: 04 nov 2007, 00:08
Medlemsnummer: N1578
Navn: Jim Slaaen
Bil: 00 Saab 9-5 Aero Estate Aut.
Re: service på 9000?
Legg inn av Jim S. N1578 » 03 jan 2010, 19:51
Raskt svar derfor på engelsk :P
Major Service B (Inclusive of Safety Service)
Check manual gearbox oil level.
Replace spark plugs.
Replace engine air cleaner element.
Replace cabin air filter.
Replace engine coolant
Replace brake fluid and bleed through the calipers.
Replace fuel filter
Replace drive belt
Replace automatic transmission fluid
Safety Service
Check lighting system: headlights, fog lights, parking, backup, brake, hazard, turn, license plate, interior and exterior lights.
Reset Service Indicator.
Change engine oil and filter while engine is at normal operation temperature.
Check handbrake function
Examine brake disc surfaces and pad life.
Check brake system connectors and lines for leaks and damage
Check outer and inner drive joint boots
Check steering for play, ball joint clearance, steering linkage, and rubber boots.
Check shock absorbers and bushings - tightness and condition
Visually check fuel tank, lines, and connections for leaks.
Check condition, position, and mounting of exhaust system. Examine for leaks.
Check power steering system for leaks.
Check overall thickness of front and rear disc brake pads.
Grease wheel center hubs.
Check exhaust system and mounting for leaks
Check all tire pressures and condition of tires (outer surfaces (left/right)), tread wear and pattern.
Rotate tires.
Check fuel system for leaks and condition
Check coolant level and antifreeze protection level; add coolant if necessary.
Check engine cooling system/heater hose connections for leaks.
Check automatic gearbox oil level and condition.
Check level of brake and clutch fluid in reservoir; add fluid if required.
Check level of power steering fluid and check system for leaks.
Check drive belt condition
Check battery electrolyte level. Clean terminals if necessary.
Check windshield washer fluid level. Fill up and/or correct if necessary.
Check wiper and washer system; wiper blades, washer jet positions.
Check and oil: hood, trunk/tailgate, door hinges and latches.
Check condition and function of safety belts.
Visually examine the SRS airbag units for torn cover or obvious damage
Road test with check of driver train performance, steering, suspension and brakes. Check function of instruments and controls, including horn, wiper, cruise control and climate systems.
Danielm
Navn: Daniel
Legg inn av Danielm » 03 jan 2010, 19:57
og pris? :shock:
Jim S. N1578
Navn: Jim Slaaen
Legg inn av Jim S. N1578 » 03 jan 2010, 20:41
Danielm skrev:og pris? :shock:
Det kan kanskje noen annen svare bedre på. Jeg vet ikke. Lest et sted om en som hørte på pris på service på en 1999 saab 9-5 ved 110000km (70 000 miles) som etter oversikten min bare skulle være en "Safety Service". Pris 11 000,- :shock: Men han snakket om at bare deler kom på 4000, så det er vel kanskje litt annen praksis i Europa enn i USA på serviceintervallene mellom mindre og større serviser og at den var en av de dyrere sevicene. Ikke vet jeg...
