Lawicel Canusb user wanted [Stjørdal/Trondheim]
Norwegian language is prohibited (or should be used VERY sparsely) in this forum, as the intent with it is to discuss with Saab-enthusiasts from countries without trolls and telemarkski. Feel free to discuss all kind of Saab-related topics, but don't make threads dedicated to own projects (links to other forums are welcome).
boosty
Registrert: 07 sep 2010, 07:05
Navn: Max
Bil: old 9-5 b235e mt
Legg inn av boosty » 27 okt 2011, 18:51
#-o
This year i bought Lawicel Canusb dongle.
Started to do connections between T7suite and trionic in car.
At first tried to hook on I-bus. Everythung works fine. Connection was established in 2-3 try time.
Then i tried to connect dongle on P-bus...
From the beginning it was so that it does not connect via P-bus trionic to t7suite with dongle using a simple twin wire about 1 meter in length.
Now once again I reached my hands to make a difference in the current situation. shortened the lead up to 50cm - nothing has changed,
duct tape was unwound in front of trionik shoe where I was soldered the wires, and tried to hook with only 5cm wire / still got nothing.
(when at first i start the suite when click on the "Connect ECU" button dongle blinks Green for 2 seconds then goes off and i see"Unable to connect" in T7suite statusbar. When i reconnect usb to PC repeating the procedure of connection (without restarting the suite) all next times dongle lights Red and then freezes t7suite)
When i connecting via the I-bus - i have access after 1-2 attempts of reconnecting usb cable.
What im thinking is try to test someones Lawicel Canusb adapter on my vehicles P-bus... :roll:
Will be happy to see the answer in PM or any suggestions at this thread.
ps: tried without 100 Ohm resister in dongle in between can-H and can-L - any attempt looks the same like with resister soldered.
/max
e85 ready
torque steering club
To do: 1 meter fire from exhaust :P
Re: Lawicel Canusb user wanted [Stjørdal/Trondheim]
Legg inn av Pål N526 » 27 okt 2011, 19:14
You dont need ground. You dont need resistor. Tried to swap the wires? Is your car an automatic?
/ Pål
boosty
Navn: Max
Legg inn av boosty » 28 okt 2011, 05:53
I dont use ground and as i posted before i tried without resistor too.
Been tried swapping a wires when connecting with 5cm cable then was noresults
Car with manual gearbox.
..I thought maybe some dramatic hardware changes in canusb dongle was done by manufacturer...... :?:
ps: forgot to say
When was hooking on desktop at home everything worked fine, and im downloaded bins and reflashed ecu couple of times.
/max
e85 ready
Legg inn av Ingvar N629 » 28 okt 2011, 06:18
Check battery voltage.
M03 Saab 9-5 Aero Hirsch original 305 hk
boosty
Navn: Max
Legg inn av boosty » 28 okt 2011, 14:05
Ingvar N629 skrev:Check battery voltage.
Voltage floating arround 14-14.2 volts according to sid symbol (engine started)
Intresting.. today one attempt to connect P-bus was good but when i opened realtime panel in t7suite i see that all "gauges" often freezes up to 2 sec.
Then i manage try to download bin from ecu - but suite freezes again.. strange #-o
e85 ready
Legg inn av Pål N526 » 30 okt 2011, 21:03
Check voltage with ign. on (not running).
place the light switch between 2 of the break points(all light shuts off 8) ).
using the correct drivers/reinstall?
Try using an other laptop?
turn off wifi.
/ d
boosty
Navn: Max
Legg inn av boosty » 31 okt 2011, 17:13
[quote="Pål N526"][/quote]
Voltage 12.2 stable @ignition on (engine, acc, music, rear gear and all the lights OFF, doors closed)
other will try later at this uke :)
/max
e85 ready
boosty
Navn: Max
Legg inn av boosty » 06 okt 2012, 18:05
Forgot to say:
everything is allright now with connection to both I & P bus`ez (i use P to flash)
i even forgot what im been done wrong))
Thanx and greetings to all ya saabguyz i Norge!!!
e85 ready
boosty
Navn: Max
Legg inn av boosty » 06 okt 2012, 18:27
and
if you se that pile of metal somwhere arround Stjørdal or Trondheim, then .. i dunno what to say :lol: 8)
e85 ready
